Brainy core Error: nginx not installed
pomoyka
Сообщение pomoyka » Чт сен 12, 2024 2:32 pm
ubuntu 22
brainy-core -h3 status
*** The instrument of setup of the kernel and the simple network analyzer for BrainyCP ***
*** Version: 0.43.9 ***
[--] Error: nginx not installed
Reinstall the Web linking in a panel with support of nginx that this option was available.
Все работает, nginx на борту, как поправить?
Re: Brainy core Error: nginx not installed
Сообщение sbury » Чт сен 12, 2024 7:15 pm
Покажите вывод
dpkg -l | grep nginx
dpkg -l | grep brainy-core
Какая версия панели?
pomoyka
Сообщение pomoyka » Чт сен 12, 2024 7:52 pm
ii brainy-nginx 2:1.22.1-10brainy3 all Nginx is a web server and a reverse proxy server for HTTP, S
MTP, POP3 and
ii brainy-nginx-all-modules 2:1.22.1-10brainy3 all A meta package that installs all available Nginx modules.
ii brainy-nginx-filesystem 2:1.22.1-10brainy3 all The nginx-filesystem package contains the basic directory la
yout
ii brainy-nginx-mod-http-geoip 2:1.22.1-10brainy3 all Nginx HTTP geoip module.
ii brainy-nginx-mod-http-image-filter 2:1.22.1-10brainy3 all Nginx HTTP image filter module.
ii brainy-nginx-mod-http-perl 2:1.22.1-10brainy3 all Nginx HTTP perl module.
ii brainy-nginx-mod-http-xslt-filter 2:1.22.1-10brainy3 all Nginx XSLT module.
ii brainy-nginx-mod-mail 2:1.22.1-10brainy3 all Nginx mail modules.
ii brainy-nginx-mod-pagespeed 2:1.22.1-10brainy3 all Nginx HTTP pagespeed module.
ii brainy-nginx-mod-stream 2:1.22.1-10brainy3 all Nginx stream modules.
ii nginx 1:1.27.0-0brainy0.22.04 all Nginx is a web server and a reverse proxy server for HTTP, S
MTP, POP3 and
ii nginx-all-modules 1:1.27.0-0brainy0.22.04 all A meta package that installs all available Nginx modules.
ii nginx-filesystem 1:1.27.0-0brainy0.22.04 all The nginx-filesystem package contains the basic directory la
yout
ii nginx-mod-http-brotli 1:1.27.0-0brainy0.22.04 all Nginx HTTP brotli module.
ii nginx-mod-http-cache-purge 1:1.27.0-0brainy0.22.04 all Nginx HTTP cache purge module.
ii nginx-mod-http-geoip 1:1.27.0-0brainy0.22.04 all Nginx HTTP geoip module.
ii nginx-mod-http-headers-more-filter 1:1.27.0-0brainy0.22.04 all Nginx HTTP headers filter module.
ii nginx-mod-http-image-filter 1:1.27.0-0brainy0.22.04 all Nginx HTTP image filter module.
ii nginx-mod-http-modsecurity 1:1.27.0-0brainy0.22.04 all Nginx HTTP pagespeed module.
ii nginx-mod-http-perl 1:1.27.0-0brainy0.22.04 all Nginx HTTP perl module.
ii nginx-mod-http-xslt-filter 1:1.27.0-0brainy0.22.04 all Nginx XSLT module.
ii nginx-mod-mail 1:1.27.0-0brainy0.22.04 all Nginx mail modules.
ii nginx-mod-pagespeed 1:1.27.0-0brainy0.22.04 all Nginx HTTP pagespeed mo
pomoyka
Сообщение pomoyka » Чт сен 12, 2024 7:53 pm
ii brainy-core 1:0.43.9-0brainy0.22.04 all Analiz for BrainyCP
pomoyka
Сообщение pomoyka » Чт сен 12, 2024 8:13 pm
сейчас попробую отыскать его.Несколько минут нужно.
Сообщение sbury » Чт сен 12, 2024 8:18 pm
support_39390
Сообщение sbury » Чт сен 12, 2024 8:26 pm
или покажите еще вывод этой команды
 dpkg -I nginx
pomoyka
Сообщение pomoyka » Чт сен 12, 2024 8:27 pm
dpkg -I nginx
dpkg-deb: error: failed to read archive 'nginx': No such file or directory
скайп готов
Сообщение sbury » Чт сен 12, 2024 8:29 pm
напишите что-то, я вас не вижу
Сообщение sbury » Пн сен 16, 2024 8:33 pm
обновите пакет brainy-core до последней версии
